1995 Other Suzuki Models Battery won't recharge from alterna
1995 SUZUKI
157,000 MILES • 4 CYL • 4WD • AUTOMATIC
SIDEKICK_AND_KICK
Something is either draining the brand new battery faster than the brand new alternator can keep up with, or something is keeping the brand new alternator from recharging the brand new battery.
I tend to think it's the latter.
I have already replaced the following:
Battery
Alternator
Fusable Link
Wiring Harness between the positive battery terminal, alternator, fusable link, and starter solenoid.
After all of this and having all the new items retested and found to be proper, the freshly recharged battery will only run the vehicle for about an hour or so before the battery is dead again.
I'm stumped and my son has been "borrowing" my gas saving Nissan Sentra for three weeks while I've done all this work between jobs and thunderstorms in the back yard.
Thank you,
Joel[img:2d69a8ea4f]http://www.2carpros.com/forum/automotive_pictures/184768_Joe_2_1.jpg[/img:2d69a8ea4f]
Apr 29, 2008 at 3:45 PM
  • 31,937 POSTS
Hi there.
Do a current draw test. fit an amp meter between Bat pos (+) & battery cable, turn on ignition (don't try and start) and see what the current draw is, key out 7 doors closed, if above .15 Amps and around .5 + you have a open circuit somewhere, to help locate start to pull fuses and when current drops you have isolated the problem circuit. Try this first.
Mark (mhpautos)
Apr 29, 2008 at 3:52 PM
SIDEKICK_AND_KICK
I will use your suggestion as soon as the sun comes up!
Apr 29, 2008 at 4:09 PM
