1991 Other Suzuki Models battery keeps dying
1991 SUZUKI
MACNEILL22
Electrical problem
1991 Other Suzuki Models 4 cyl Four Wheel Drive Manual
the battery keeps dying what else could it be if the alternator is fine?
Jul 29, 2008 at 3:51 PM
  • 31,937 POSTS
Hi there,
Charge the battery and have it load tested, this is the best way to test a battery, check the terminals are clean & tight and if these are OK, have your mechanic do a current draw test, this will show if any circuit is active when the key is off and causing the battery to drain, the Alt should also be tested for a current drain as a faulty diode will back drain the battery, but will also still shoe an acceptable charge rate.
Mark (mhpautos)
Jul 29, 2008 at 5:58 PM
KDX_GREEN
My battery kept going dead on my 1991 Suzuki Swift. I tapped the battery cable on the battery and noticed there was a clicking sound coming from inside the door.I removed the door panel and the seloniod(SP) was making a clicking sound when the battery was hooked up. I unhooked to wire and that fixed the problem.
Dec 25, 2009 at 9:25 AM
