1994 Suzuki alternator and fuse
1994 SUZUKI
200,100 MILES • 4 CYL • 4WD • AUTOMATIC
BOOSLUVR518
replaced ground wire on alternator and it blew the 60 am fuse...any ideas?
Dec 7, 2007 at 3:25 AM
DAVE H
  • 13,384 POSTS
double check you are grounding the correct wire !
Apr 8, 2009 at 2:25 AM
KICK-FIX
  • 29 POSTS
what ground there is only a case ground.
or are you plugging in the rear small connector.
id say , the alternator is shorted inside.
id remove it take it to any parts store to be tested.
then buy a fuse after test passes.
Sep 2, 2009 at 11:50 AM
