1993 Other Suzuki Models NO POWER
1993 SUZUKI
78,000 MILES • 6 CYL • 4WD • AUTOMATIC
THEHOGG
I have checked everything I know to check. The computer is good and I just put a new timing belt on it. The computer doesn't show any bad sensors. What esle should I check? The car is a Suzuki Sidekick
Dec 26, 2007 at 6:39 AM
1993 Other Suzuki Models NO POWER-just exactly what do you meant by this-give me more details to work with. Are you talking about moving like a jack rabbit after a stop?
Changing a timing belt requires special procedures-did you follow the repair manual accordingly step by step.
Dec 27, 2007 at 4:16 PM
MORT
  • 7 POSTS
I have a 1995 Geo Tracker (same as sidekick). I had a power loss and it turned out to be the coil. The mechanic had it for three days and replaces the fuel pump(which I didn't need). It runs fine now.. Mort
Mar 5, 2008 at 7:30 AM
