1993 Other Suzuki Models Blowing fuses
1993 SUZUKI
200,000 MILES • 4 CYL • 2WD • MANUAL
WIMBLEY
I have an 93 suzuki sidekick 16v 4 cyl. i have two issues. It is sparatically blowing the fuse for the fuel pump. It does not occur constantly. I have checked the wires for a ground fault but can not find one when the problem occurs. I replace the fuse and it runs fine for a while till blowing the next fuse. Any suggestions? Another issue it is also blowing, but not at the same time, fuse 9 which is for the turn signals and back up lights. this happens as soon as the vehicle is started without either light being in use. It is constant and will not hold. i have also checked the wires for a ground fault and have found none. Please assist me if possible. Thank You
Mar 16, 2008 at 1:29 PM
DAVE H
  • 13,383 POSTS
replace the fuel pump
Apr 24, 2010 at 8:00 PM
