1992 Other Suzuki Models engine cannot start
1992 SUZUKI
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
YOCOC_15
  • 5 POSTS
already two months that my car cannot start, first it will start and run then when i stop the car it will not start anymore..until now many techinicain already complaining that the problem is the control box.... indicator lamp for ignition donnot display..i need your help how to fix the said problemmm
Dec 27, 2007 at 4:03 PM
  • 75,988 POSTS
Disconnect a sparkplug wire or two and ground it to the engine and have helper crank engine over while you look for spark-do you have it and what color is it-do this and comeback. I'll be standing by.
Dec 27, 2007 at 4:11 PM
YOCOC_15
  • 5 POSTS
their is a blue spark color doing the said activity
Dec 27, 2007 at 10:14 PM
  • 75,988 POSTS
Do you smell gas on the throttle body-if not spray carbuerator cleanet in it-did it start and dies out. If so you need to check the fuel pressure.
Dec 28, 2007 at 2:59 AM
YOCOC_15
  • 5 POSTS
fuel pressure is ok...its ignition coil also ok...last time if the indicator lamp on its will start but now indicator cannot display on the instrument panel
Dec 28, 2007 at 8:05 AM
  • 75,988 POSTS
You got fuel pressure but is the fuel getting into the engine cylinders find out what's the status with the injectors.
Dec 28, 2007 at 4:08 PM
YOCOC_15
  • 5 POSTS
yes their is gasoline going to the engine cylinder....injectors are okey...
Dec 28, 2007 at 4:38 PM
  • 75,988 POSTS
Did you do a spark test like I've said on my 1st suggestion. Do that and let me know if you have spark.
Dec 28, 2007 at 9:20 PM
YOCOC_15
  • 5 POSTS
yes I already do what you said ..there is a spark ( blue flame) while doing the spark test...
Dec 29, 2007 at 12:18 AM
