Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Suzuki
Other
Electrical
Electrical Shut Down
1989 Other Suzuki Models no power to anything
1989 SUZUKI
104,000 MILES • 4 CYL • 4WD • MANUAL
DAVID542
MEMBER
I can't power to anything with key off or on. I check the fueses, and battery they are good.
What do I check for now?
Dec 23, 2007 at 7:47 AM
Experienced Mechanic
Power from the battery has to go thru all the fusible links to get to the ignition switch and in turn power controlled devices.
Dec 23, 2007 at 7:51 AM
DAVID542
MEMBER
Before I took the battery out, it was fine, then later put it back in, that is when all this happen.
Where is the fuesable links located at, and could I have bumbed something?
Dec 23, 2007 at 11:14 AM
The fusible links should be in the power distribution box or atteached to the positive battery or to the starter.
Doube check the battery connections make sure its clean and tight and negative cable to the engine and engine to firewall
Dec 23, 2007 at 2:14 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
