1986 Other Suzuki Models How to replace a water pump
1986 SUZUKI
TRINI720
Engine Cooling problem
1986 Other Suzuki Models Two Wheel Drive Manual
How to replace a water pump on a 1986 suzuki Swift
Apr 7, 2008 at 3:15 AM
DAVE H
  • 13,384 POSTS
Drain cooling system. Disconnect battery. Remove pump pulley and drive belt. Remove lower radiator hose. Ensure that No. 1 piston is at TDC of compression stroke.
Remove crankshaft pulley, timing belt cover, timing belt, camshaft sprocket and timing belt tensioner. Remove pump.
May 29, 2010 at 10:17 PM
