1997 Suzuki Omni FAULT
1997 SUZUKI OMNI
15 MILES • 4 CYL • 2WD • MANUAL
ANANDIBM2001
Dear sir,
i am interested in car timing setting in camshaft and crankshaft setting for timing belt fitting and distributor setting How to position the piston at TDC and the setting of timing and crankshaft sprocket.How to check the alignment in flywheel for TDc
Thanks
anand
Apr 24, 2009 at 1:48 PM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
we do not have the spec's for this vehicle i'm afraid .. your local autoparts store should be able to supply a manual for the vehicle with step by step instruction and diagrams !!
Apr 26, 2009 at 10:06 AM
