Suzuki K12MP timing marks”?
161,357 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
HAMUDIABDU2026
Camshaft timing error how can I know it
Mar 17, 2026 at 9:08 AM
  • 55,845 POSTS
What kind of error codes are you getting? Also, does the engine make a slight rattle noise at idle when cold? If so this is sign the timing chain system is worn out and will cause camshaft codes, if you upload a short video form under the hood of the engine running when cold I can tell for sure if this is the problem. Ken
Mar 18, 2026 at 1:26 AM
