Shuts off while driving
2001 SUZUKI IGNUS
67,000 MILES • 4 CYL • FWD • MANUAL
SDH
Over the last week my vehicle just stops as I am driving along. Two symbols appear a car with a padlock and an oval shaped sign above they both flash on/off consecutively then both come on together where the car just stops. After about 10 minutes the car will start without any problems then it occurs again and I have to repeat the process until I get home. Some days it's absolutely fine. As the car is second hand I didn't get a handbook so I don't know what the symbols mean. Hope you can help
Jun 30, 2009 at 1:32 PM
SQM
  • 6,383 POSTS
It sounds like this issue might be due to a faulty crankshaft position sensor.
The crank position sensor is located on the lower part of the engine next to the crank pulley.
It picks up the rotations of the crank shaft and sends that information to the ECM.
With all the heat and vibration from the engine the sensor can go bad over time. This will cause the sensor to send incorrect data to the ECM, the result is a stalled engine.
Here are few helpful articles:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
When a crank sensor fails, it can trigger the check engine. If your check engine light is illuminated, then get it scanned for code(s). This can help with the diagnostics.
Sep 21, 2021 at 2:04 PM
