2008 Suzuki Forenza
AUNDER89
2008 Suzuki Forenza
My car only has about 34,000miles on it and so far no problems. However, anytime we use the turn signal, the wipers come on and the car accellerates slightly. Now my check engine light is also on and was not until the started happening yesterday. What do I do?
Jun 12, 2010 at 2:52 PM
  • 31,937 POSTS
Hi there,
This is rather odd indeed, but a s you have a check light on, the first thing we need to know is the set fault code in the ECU, get a scan done and report the code/s here.
Mark (mhpautos)
Jun 12, 2010 at 5:51 PM
AUNDER89
We had AutoZone run the diagnostic, and 2 codes came up
P2106
P2138
They did not have my car in the database so they could not tell us what the codes meant.
Jun 14, 2010 at 8:02 AM
  • 31,937 POSTS
Hi there,
From what i can find on line, this is a problem with the throttle position sensor and the pedal position sensor, this will be a dealer fix, i do suggest that you discuss this with your dealer.
mark (mhpautos)
Jun 14, 2010 at 10:20 AM
