2007 Suzuki Forenza Serpentine Belt
25,000 MILES • 4 CYL • FWD • MANUAL
SLEEPERS03
I recently took my car into be serviced and there were multiple problems. on of which an oil gasket something has to be replaced because of an oil leak, also the enitre heating system and then entire windshield washer resivore. All the above problems are covered under warranty. They also said that the serpintine belt needs to replaced and that it's not covered under warranty cause it's maintence issue. The car is 11/2 years old with 25k miles. Do serpentine belts go bad that quickly or did the oil leak cause it to go bad?
Jan 27, 2009 at 10:17 AM
DAVE H
  • 13,383 POSTS
could just be wear and tear ..!!
Apr 29, 2009 at 3:05 PM
