2006 Suzuki Forenza Inside door handles
40,899 MILES • 4 CYL • FWD • AUTOMATIC
MILLSJS
How do you replace the inside door handles
Feb 19, 2010 at 10:20 AM
DAVE H
  • 13,383 POSTS
Inside Door Handle Removal and Installation Removal Remove the door seal trim. Refer to DOOR SEAL TRIM REMOVAL AND INSTALLATION . Remove the tweeter speaker (if it is equipped) and the screw. Slide the door handle forward and remove it from the door. Disconnect the inside door handle and the lock rods. Installation Connect the inside door handle and the lock rods. Insert the inside door handle into the slots in the door. Slide the door handle rearward. Install the inside door handle screw. Install the door seal trim.
https://images.2carpros.com/forum/automotive_pictures/266999_suz_1.png
Mar 14, 2010 at 11:35 PM
UNIQUEEL
Would you mind pointing to the instructions for removing the trim around the inside door handle.
Jul 25, 2010 at 2:06 PM
