2006 Suzuki Forenza DRL
40,000 MILES • 4 CYL • 2WD • MANUAL
SILVERWING444444
Would somebody know why my Daylight Running Lights won't come on. I have a 2006 Suzuki Forenza sedan. The little light on the dash lights up when my headlights are off and the emergency brake handle is all the way down. That light tells me if my Daylight Running Lights are on but they don't come on when I start the engine. I can't find a fuse or can't figure out which one it could be. I can't find a switch either. I can buy a pair of low beem lights but If the lights are good, then that would be $40.00 wasted. Thanks. Tom
Jul 16, 2010 at 7:02 AM
TULLOHOMA1374
FAULT IS INTHE CONNECTER BEHIND THE INSTUMENT CLUSTER. SEE THE TSB FOR THE REPAIR. WIRING END LINK WITH BLUE, GREEN AND 3 PURPLE WIRES IS YOUR TARGET. SEPERATE 3 PURPLE WIRES OUT FROM CONNECTER AND PUT INTO THEIR OWN CONNECTER.
Jul 16, 2010 at 3:13 PM
