Head bolt torque specs
AVENGER1265
2005 Suzuki Forenza 4 cyl Front Wheel Drive Automatic
what is the torque spec for the head bolds and cam cap bolts on suzuki forenza 2005
Feb 27, 2010 at 12:29 PM
  • 55,588 POSTS
Here are the head bolt tightening instructions and some diagrams of the job being done (below). Start by disconnecting the battery.
Tighten the cylinder head bolts gradually and in the sequence shown. Tighten: Tighten the cylinder head bolts to 25 Nm (18 ft. lbs.) and turn the bolts another 3 turns of 90° using the angular torque gauge KM-470-B.
Camshaft bearing cap bolts tighten to 71 INCH Lbs. (8 N.M)
Cheers, Ken
Oct 13, 2017 at 7:45 AM
