2005 Suzuki Forenza misfiring
97,000 MILES • 4 CYL • FWD • AUTOMATIC
JEFFREY.73
I simply wanted to know why my car is making a slight rumbling/popping noise? It only appears to do it after I have been driving it for atleast 10-15 minutes or longer. My instincts tell me its misfiring because the coil pack/ignition coil is about to go out on it. Is this correct?
Apr 1, 2010 at 5:27 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Apr 20, 2010 at 8:37 AM
