2005 Suzuki Forenza hi beam switch
77,750 MILES • 4 CYL • 2WD • AUTOMATIC
AXLEROD
  • 5 POSTS
hi
when i push down on headlight switch the hibeam light won't come on.when i pull up on switch hibeam light come on (which is wrong position).
When i watch the lights outside of car every light seems to be working. How do i troubleshoot problem
Thanks axlerod
Dec 31, 2009 at 12:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if headlamp relay is OK then check wiring to switch. if wiring checks out good too then suspect faulty headlamp combination switch.
Dec 31, 2009 at 12:55 PM
