Hard to start in mornings-plugs replace
2005 SUZUKI FORENZA
27,000 MILES • 4 CYL • 2WD • MANUAL
MANNY71
Car has low mileage-27,000, water pump & timing belt replaced in 2007. Plugs replaced-one had a rusty plug. Not overheating. Once its started in the morning-takes a while- it runs all day with no problem starting again. Its only the mornings it doesnt like to start. You can hear the fuel pump come on when you turn the key to start. What can be the problem or what can I check to see what the problem could be?
May 21, 2010 at 2:45 AM
SQM
  • 6,383 POSTS
Hard to start can be due to a number of different reasons. It could be weak fuel pump, dirty throttle bore, worn out spark plugs, low cylinder compression, faulty mass air flow sensor.
It is possible to have hard start when it is cold due to a failing fuel pressure regulator. And as it warms up the regulator functions properly and you don't have any starting issue.
Thake a look at this helpful guide:
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
A good first step would be to check the fuel pressure when the engine cold. This can help determine the issue. With the key on and engine off it should have 55-57 PSI of fuel pressure.
It will also be a good idea to check and clean the intake components like the throttle body and the mass air flow sensor.
https://www.2carpros.com/articles/mass-air-flow-service
Dec 5, 2021 at 12:41 PM
