2005 Suzuki Forenza
95,000 MILES • 4 CYL • 2WD • MANUAL
NEVER 2 LATE
The clutch has lost pressor, like if it has stayed stuck in gear, how many different parts does a clutch system have?, How dificault is it to repair and how much will it run me.
Aug 3, 2009 at 6:05 AM
2CARPRO JACK
  • 11,533 POSTS
Price is hard to tell until you know what is wrong.Look for fluid leaks first.The clutch system (hydraulic) has 2 main parts, the master cylinder, and the slave cylinder.If there is fluid leaking out of either one it needs to be replaced, then the system needs to be bled to get rid of all the air. At 95k it may very well need a clutch, you may want to consider having a shop check it out if there are no obvious leaks in the system
Aug 3, 2009 at 1:52 PM
