2004 Suzuki Forenza throttle
2004 SUZUKI FORENZA
65,000 MILES • 4 CYL • 2WD • MANUAL
MCSNOWBALL
When in neutral gear my Suzuki's engine rev's up to 3000 RPM when idling. Could this be a throttle adjustment or a throttle sensor problem? If not could it be a clutch problem? The engine also seems to take a few extra seconds to shut down when the key is removed from the engine.
Feb 5, 2010 at 3:18 PM
DAVE H
  • 13,384 POSTS
check for vacuum leaks .. check throttle position sensor
Apr 30, 2010 at 6:19 AM
