2004 Suzuki Forenza Rapid misfire
80,000 MILES • 6 CYL • FWD • AUTOMATIC
SJHATCHETT2024
We have changed the spark plugs, wires, oil, filter, replaced both O2 sensors, replaced the oil valve gasket cover (it was leaking oil in the spark plug chamber) and car is still misfiring. What else could cause this problem, it is so bad I can not drive it.
Feb 24, 2010 at 11:12 AM
DAVE H
  • 13,383 POSTS
replace the crankshaft position sensor .. check/clean fuel injectors
Apr 29, 2010 at 10:48 PM
