2004 Suzuki Forenza POWER WINDOW
70,000 MILES • 4 CYL • AWD • AUTOMATIC
MOTHERDUCK
MY WINDOW ON THE DRIVER SIDE WONT GO UP AFTER PUTTING IT DOWN FOR 5 MINUTES. MY OTHER 3 WINDOWS ARE FINE. SOMEBODY SUGGESTED MOTOR OR SWITCH. WHAT SAY YOU?
Mar 11, 2009 at 6:05 AM
DAVE H
  • 13,383 POSTS
remove thr drivers door trim panel and check for power to motor witha multimeter .. if you have power .. check the motor works with a direct feed and ground from the battery !
Mar 23, 2009 at 1:56 PM
