HAD A OIL LEAK AND TOOK IT TO GET FIXED,NEW GASKET AND OIL CHANGE.TOOK IT OFF LOT AND STARTED MISSING IN DRIVE ALSO WHEN GOING 55 ITS WORSE TOOK IT BACK AND THEY PUT A VACUMM HOSE ON IT .SAID THAT WAS THE PROBLEM . NOT SO CAUSE ITS STILL MIS FIRING AND LIGHT CAME ON FOR 2 MINUTES THEN WENT OUT, ITS GETTING WORSE DRIVING IT PLEASE TELL ME WHAT THE PROBLEN IS THANK YOU
May 16, 2008 at 3:32 AM
