2004 Suzuki Forenza Engine Running Hot and Losing Water
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAMELADAVIS80
I've had the radiator replaced and the head gasket. The mechanic says the heads aren't cracked or warped but the car is losing water. There are not visible leaks from any hoses or containers. The engine runs hot after driving the car for less than five minutes, it hesitates as if I purchased some bad gas and when stopped the car idles up and down. The mechanic is now saying a new thermostat will correct the problem. What should I do?
Oct 7, 2010 at 1:31 AM
  • 75,988 POSTS
Hi pameladavis80, Welcome to 2carpros and TY for the donation
Have him replace it-if it continues checked the water pump and also have him bleed the cooling system
Oct 7, 2010 at 1:54 AM
