2007 Suzuki Esteem brake vacuum leaking
16,000 MILES • 4 CYL • 2WD • MANUAL
UDEYDEEP
my car's vacuum pressure leaks out when it is parked in stopped engine position. resulting leaking vacuum , brake paddle goes hard . brakes cannot stop car without putting extra pressure by my foot. on starting engine it starts working normally .
1 should i keep my car driving in this position ?
2 what you suggest i do ?
Jul 17, 2009 at 8:45 PM
  • 31,937 POSTS
Hi there,
Do not drive with the brakes like this as it is very dangerous, i would be checking that the Vacuum check valve at the booster in let is ok, and then have the booster check for vacuum leaks,start here.
mark (mhpautos)
Jul 17, 2009 at 8:47 PM
  • 75,988 POSTS
Your safety is in danger do not drive the vehicle. The brake booster could be leaking or also the hose to it
Jul 17, 2009 at 8:56 PM
