2007 Suzuki Esteem brake vacuum leaking
UDEYDEEP
  • 2007 SUZUKI ESTEEM
  • 4 CYL
  • MANUAL
  • 16,000 MILES
My car's vacuum pressure leaks out when it is parked in stopped engine position. Resulting leaking vacuum, brake paddle goes hard. Brakes cannot stop car without putting extra pressure by my foot. On starting engine it starts working normally.
1 should I keep my car driving in this position?
2 what you suggest I do?
Saturday, July 18th, 2009 AT 3:45 AM
  • 31,937 POSTS
Hi there,
Do not drive with the brakes like this as it is very dangerous, I would be checking that the Vacuum check valve at the booster in let is ok, and then have the booster check for vacuum leaks, start here.
Mark (mhpautos)
Saturday, July 18th, 2009 AT 3:47 AM
Your safety is in danger do not drive the vehicle. The brake booster could be leaking or also the hose to it
Saturday, July 18th, 2009 AT 3:56 AM
