2001 Suzuki Esteem removal of lower right control arm
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
WLDAY18
I need to replace the lower right control arm. The problem is trying to remove the front bolt, it just spins.
Tried to remove remove the suspension frame but the bolts just round out.
Feb 12, 2009 at 11:49 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please let me know if your model is a GL, GLX, GLX+. Also I need to know your engine size in liter.
Feb 12, 2009 at 3:10 PM
WLDAY18
2001 Suzuki Esteem GLX 4dr SDN 1.8L
Feb 12, 2009 at 9:38 PM
IMPALASS
  • 3,112 POSTS
Hello - Glad to hear back and thanks for the info.
https://images.2carpros.com/forum/automotive_pictures/248015_Picture2_39.jpg
I only see 3 connection points. The one is to the ball joint - nut you have that off. The next is the bolt that goes to the frame that I do not have marked and that has a nut. Is this the one you said is stripped? Are you using metric tools - did you see the nut - did you try penetrating oil first and let it soak? The next bolt I see is the one I have circled - is this the one you said just spins? I can not see from the pic but is there a nut on it? Can you stick a punch through the other side and as you turn it to back it out push with the punch to move it out? Penetrating oil.....have you put any there? Does any of this help? Are we on the same page?
Feb 13, 2009 at 1:51 AM
WLDAY18
I finally cut it off.
The bolt and bearing where frozen together.
Feb 13, 2009 at 3:10 AM
IMPALASS
  • 3,112 POSTS
Hello –
Well – glad you got it apart……….sometimes that is the only route – besides a hammer we should always have a good cutting tool in our box
Thanks for the info/update
Feb 13, 2009 at 6:10 AM
