2001 Suzuki Esteem OBD 2 PO481 CODE
139,000 MILES • 4 CYL • FWD • AUTOMATIC
HELLKER
I HAVE A BAD RELAY BUT I CAN'T SEEM TO FIND IT ANYWHERE ON LINE TO BUY, I ALSO AM HAVING TROUBLE GETTING IT AT A LOCAL AUTO PARTS STORE. IT IS MADE BY OMRON AND THE PART NUMBER IS G8MS-1A25T IT IS A 12V 20 AMP AND THERE ARE MORE NUMBERS UNDER THAT THAT ARE 0570D.
MY QUESTION IS: IS THIS RELAY THAT IS BAD CONNECTED TO THIS OBD 2 CODE OR IS IT SOMETHING COMPLETELY DIFFERENT?
Feb 3, 2009 at 1:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
P0481 Cooling Fan 2 Control Circuit Malfunction
It is a very good possibility that the relay you are trying to purchase is indeed the relay for the cooling fan.
Try searching the Omron site for the part or you should be able to locate the relay at your local dealer.
Thanks for using 2CarPros.com!
Feb 3, 2009 at 2:51 PM
