1997 Suzuki Esteem reapairs
206,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAY1945
how do i remove the interior front door panel to get at the door latch front driver side
Jun 23, 2009 at 4:58 PM
BUDDYCRAIGG
  • 2,262 POSTS
there will be plastic clips along the front and rear edge and the bottom. those you can just "pop" away from the door. but there are going to be some screws also.
look for the screws, they may be hiding under little covers that pop closed probably (about the size of a dime or maybe a little bit smaller)
there's going to be screws where you pull the door shut also, be it a hole in the arm rest or a grab handle or a strap. there will something there to firmly attach the handle to the metal part of the door.
good luck
Jun 24, 2009 at 3:12 AM
