1997 Suzuki Esteem car wont start
370,000 MILES • 4 CYL • 2WD • AUTOMATIC
HEARTBREAKERDT
i was having problems with my ignition wires, where i would have to twist them and take them off and put them back on to make my car start. now that i bought the ignition wires put them on correctly and it still wont start. what are some other things that it could be to make it not start
Dec 14, 2009 at 7:40 AM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 14, 2009 at 8:24 AM
