Four wire come to the in tank fuel pump, what does each wire do? Fuel pump is new; relay and fuse good but fuel pump does not run?
Mar 8, 2010 at 2:42 AM
✓Experienced Mechanic
Hi there,
2 wires for the fuel pump, pink & black, and two for the sender unit, check the pink wire when you first turn on the ignition, start here.
mark (mhpautos)
Apr 18, 2010 at 11:29 PM
