1999 Suzuki Alto Blue Smoke
1999 SUZUKI ALTO
IS_TARAR
Engine Performance problem
1999 Suzuki Alto Front Wheel Drive Manual 120000 miles
My car gives a huge amount of smoke when I start it in the morning.
Dec 3, 2009 at 10:57 PM
MERLIN2021
  • 17,250 POSTS
Can be worn valve guides, valve stem seals, or even piston rings...need a compression test, also add a few drops of oil to the cylinder and retest, this will raise compression if the rings are worn!
https://www.2carpros.com/dia/how_to_check_compression.htm
Dec 3, 2009 at 11:03 PM
