2004 Suzuki Aerio Crank Angle Sensor
EMERALDSAGE
Computer problem
2004 Suzuki Aerio 4 cyl Two Wheel Drive Automatic 30K miles
It seems I need to replace the crank angle sensor, and I have gotten jerked around a lot by 2 dealerships and an independent repair shop (quotes jumping around, differing information). Really all I want to know is how difficult of a repair is it. I've been told its under the spark plug, behind the transmission, and various other locations.
I can get the part for about $200 online, they want to charge 350 plus labor which goes to around $500-700 is that reasonable?
Apr 16, 2008 at 11:19 AM
DAVE H
  • 13,383 POSTS
Crankshaft Position (CKP) Sensor Removal and Installation Removal Remove engine with transmission from vehicle referring to ENGINE ASSEMBLY REMOVAL AND INSTALLATION . Remove transmission from engine and then remove flywheel or drive plate from crankshaft. Disconnect connector from crankshaft position sensor. Remove crankshaft position sensor (1) from cylinder block (2). Installation Reverse removal procedure noting the following. Check to make sure that crankshaft position sensor (1) is free from any metal particles and damage. Apply engine oil to O-ring of sensor. Install crankshaft position sensor to cylinder block (2) with specified torque. Tightening torque Crankshaft position sensor bolt (a): 6 N.m (0.6 kg-m, 4.5 Lb-ft) Fig. 28: Installing Crankshaft Position Sensor To Cylinder Block Courtesy of SUZUKI OF AMERICA CORP.
https://images.2carpros.com/forum/automotive_pictures/266999_suz_7.jpg
Connect connector and fix wire harness with clamp securely.
Nov 8, 2009 at 11:13 AM
