2003 Suzuki Aerio wheel bearings
2003 SUZUKI AERIO
14,000 MILES • 4 CYL • FWD • AUTOMATIC
MAJACKWI
I have been told that my front left wheel bearing needs to be replaced. Can you just replace the wheel bearing or do you need to replace the whole wheel hub assembly? Also, would this problem cause excessively tire wear on the rear of the car??????
Apr 24, 2009 at 3:45 AM
DAVE H
  • 13,384 POSTS
front wheel bearing would not cause a rear tire uneven wear ? ...
By rotating wheel actually, check wheel bearing for noise and smooth rotation.
If defective, replace bearing.
Apr 26, 2009 at 3:12 AM
