2002 Suzuki Aerio change tire size-speedometer reset?
95,000 MILES • 4 CYL • 2WD • MANUAL
WILLYB904
I recently changed the tires from 14" to 16" but checked the diameter of both to find it's only changed a half inch taller. If the speedometer read differently because of this, how would i fix it where it needs to be?
Dec 18, 2007 at 10:52 AM
DAVE H
  • 13,383 POSTS
the speedometer use's readings from the transmission/gearbox not wheel revolution !!
Nov 8, 2009 at 11:08 AM
