Suspension Torque Specs?
109,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
HALEYJM77
What are the Front and Rear Suspension Torque Specs for all Bolts on a 2005 Pontiac Grand Am GT 3.4V6 ?
Mar 1, 2026 at 4:17 AM
  • 55,688 POSTS
Here are the front and rear suspension torque specs as requested.
FRONT SUSPENSION TORQUE SPECS
Strut-to-knuckle bolts (2 large bolts): 133 ft-lbs
Upper strut mount nuts (3 at strut tower): 22 ft-lbs
Strut shaft nut (center nut): 52 ft-lbs
Front control arm bushing bolt: 81 ft-lbs
Rear control arm bushing bolt: 133 ft-lbs
Ball joint pinch bolt (at knuckle): 37 ft-lbs
Tie rod end nut (to knuckle): 44 ft-lbs
Jam nut: 35-40 ft-lbs
Sway bar end link nuts: 17 ft-lbs
Sway bar bracket bolts (to subframe): 37 ft-lbs
Axle nut: 118 ft-lbs
Hub-to-knuckle bolts (rear of knuckle): 96 ft-lbs
Brake caliper bracket bolts (front): 96 ft-lbs
REAR SUSPENSION TORQUE SPECS
Upper shock mount nut: 22 ft-lbs
Lower shock bolt: 81 ft-lbs
Hub-to-axle beam bolts: 70 ft-lbs
Rear axle nut (if applicable): 118 ft-lbs
Let us know if you need anything else. Please use 2CarPros anytime we are here to help. Ken
Mar 2, 2026 at 1:11 AM
