Suspension noise
90,600 MILES • 6 CYL • 2WD • AUTOMATIC
LISAMC72
  • 14 POSTS
After replacing struts, motor mounts, tires, control arms with bushing and sway bar links, I still hear knocking noise front passenger side going over bumps
Sep 9, 2018 at 8:22 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It is kind of hard to diagnose sounds without seeing/hearing. Is there a chance you might be able to have someone make a video with a phone while you are driving and upload it here? I have attached a tutorial for you to look at. Hope this helps and hope to hear from you soon. Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/whirring-sound
Sep 9, 2018 at 12:04 PM
LISAMC72
  • 14 POSTS
Thanks for replying and the link you sent Danny L. The noise is a knock or clunking coming from the front end when going over bumps. Sounds like something in suspension is loose, but most of that has been changed out just last week. I will try and post a video.
Sep 9, 2018 at 9:21 PM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, that would help. Hope to hear back from you soon and thanks again for using 2CarPros.
Danny-
Sep 10, 2018 at 4:59 AM
LISAMC72
  • 14 POSTS
Hi Danny L, I cannot seem to get a good video to produce the sound. Given all the parts I said were already replaced do you have any possible causes for the clunk/knocking in front end?
Sep 10, 2018 at 10:22 PM
STEVE W.
  • 15,401 POSTS
You replaced the struts, did that include the strut bearings as well? Do you hear the clunk if you turn left-right or only while hitting bumps? If you are stopped can you make it clunk by bouncing the front end?
Sep 14, 2018 at 11:27 AM
LISAMC72
  • 14 POSTS
Hi Steve W, I brought the vehicle in a year ago because I was hearing the clunk/knock noise going over bumps primarily in front right side and thought they replaced both struts and full assembly. I found out they only replaced Rt/Sd strut and mount . I started hearing the noise again a few months ago and brought it back in and once again they replaced the same thing, but it was under. Noise came back after few weeks so they inspected and said nothing wrong with strut or anything else they could see so I went for a second opinion and they replaced everything in suspension except strut and assembly and after $1,450.00 still have noise! He offered to replace it with a Quick Strut and cut me a deal but I am not convinced that is where the noise is coming from since neither mechanic is sure that is the problem. I do not have any more money to throw at guesses.
Sep 15, 2018 at 12:54 AM
STEVE W.
  • 15,401 POSTS
See if any of the shops near you has a chassis ear. It is a simple amplifier and piezo sensor set up that you connect to various parts then listen for the noise. You move them around until you center on the item making the noise. If you are driving along and hear the noise, does it change if you step lightly on the brakes? How about if the wheel is slightly turned?
Can you make it clunk if you steer back and forth to rock the car while moving slow?
Sep 15, 2018 at 3:02 AM
LISAMC72
  • 14 POSTS
I can hear it when turning if going over a bump while turning but it does not seem to make the noise steering back and forth to rock the vehicle. Thanks for the advice so far and I will have to call around. Would a bad strut, strut mount, strut bearing cause a knocking sound? I have noticed it is not as present since all the other suspension parts were replaced.
Sep 15, 2018 at 7:26 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, those things could possibly cause that sound. If the upper strut mount is not properly seated when installed to the new strut assembly it makes all kind of knocking sounds. I had that happen on a Scion.Too bad you could not upload a video making the sound. Best way to determine is putting vehicle on a hoist and get underneath and inspect/manipulate to hear the sound. Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 15, 2018 at 10:17 AM
LISAMC72
  • 14 POSTS
Thanks Danny, are there any other possible causes for the knocking noise besides worn or loose suspension parts? I drove over several speed bumps today and not a sound but if that right side tire makes the first contact with the bump or dip in the road you hear it and can even feel it.
Sep 15, 2018 at 11:10 AM
DANNY L
  • 5,648 POSTS
Hello again.
Worn/loose/defective suspension component(s) is really all it can be. It would be best to have it inspected to be able to tell where the sound is coming from. Hope this helps and thanks again for using 2CarPros. Let us know what the shop/mechanic finds.
Danny-
Sep 15, 2018 at 11:32 AM
LISAMC72
  • 14 POSTS
Thanks, should I replace the right strut with a Quick Strut and is it true you have to replace both struts if you are doing one?
Sep 15, 2018 at 1:27 PM
DANNY L
  • 5,648 POSTS
Hello again.
Is Quick Strut a Brand name? Yes, It is always suggested to replace struts as a pair. As I stated before you should have the car put on a hoist and inspected by a competent mechanic to hear what/where the noise is before replacing anything. Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 16, 2018 at 4:23 AM
LISAMC72
  • 14 POSTS
Thanks so much you all for trying to help me with this! Yes, it is a Monroe Quick Strut. I took some video but still do not think it truly captures the sound. Please excuse my dirty car.
Sep 16, 2018 at 6:39 AM
STEVE W.
  • 15,401 POSTS
Quick Strut is a brand name but it also is sort of generic for a complete strut assembly, mount, strut and spring all in one bolt in unit. The noise is a bit hard to hear, it sort of sounds like a strut bearing but hard to say for 100%. Can you get a helper for a few minutes, preferably someone large who can push down on the car so it can rebound like you hit a big bump? If so put your hand on the top of the strut mount and have them give it a good bounce. If it is the bearing you will feel the strut stud sort of snap up and down as the bearing moves in the mount.
Sep 16, 2018 at 8:59 AM
LISAMC72
  • 14 POSTS
I am not sure how to get to the strut mount due to the cover over it or how to remove that to expose it.
Sep 16, 2018 at 9:42 AM
STEVE W.
  • 15,401 POSTS
You should be able to feel it if you put your hand on the cover or even if you press over a mount bolt but it depends on how sensitive your hand is.
Sep 16, 2018 at 11:45 AM
LISAMC72
  • 14 POSTS
Hi guys, the noise was the strut and the same strut they replaced twice already. Maybe third times the charm. Thank you both for your help!
Sep 21, 2018 at 10:37 PM
DANNY L
  • 5,648 POSTS
You are welcome!
Danny-
Sep 23, 2018 at 2:19 PM
LISAMC72
  • 14 POSTS
Hello guys, it is me again. You will not believe it but the same strut has failed again! I just started hearing the noise yesterday. First and second time they replaced strut and mount but they never replaced the whole assembly and third time I think they replaced the strut only. Do y’all have any idea why this would keep happening? Should they have replaced the entire assembly when it was under warranty and leaking?
Oct 14, 2018 at 2:44 AM
DANNY L
  • 5,648 POSTS
Hello again!
Yes, they should replace the whole assembly as new. If this keeps happening with their work on your car for the same problem! Sorry about your bad luck and thanks again for using 2CarPros.
Danny.
Oct 14, 2018 at 6:48 PM
LISAMC72
  • 14 POSTS
Thanks Danny, I am thinking about bringing it to a different Buick repair shop, but it is far from me and I do not know if I should be driving the vehicle around like this.
Oct 14, 2018 at 9:09 PM
DANNY L
  • 5,648 POSTS
Hello again.
I am so sorry to hear about the same problems that shop is giving you. What seems to be the problem? Are they just tired of dealing with you and it being their fault? Tell them to just fix it, and fix it right already. Again, sorry to hear about the bad luck, but all of us here at 2CarPros are always here to help.
Danny-
Oct 14, 2018 at 9:55 PM
STEVE W.
  • 15,401 POSTS
You do not need to take it only to a dealer. I would probably find an independent shop and pay them to at least look at it and diagnose the problem. It is possible that everyone has developed tunnel vision of it being the strut that is the problem when it is something else that is the root cause.
Oct 15, 2018 at 12:56 AM
LISAMC72
  • 14 POSTS
Thanks Steve, I dropped it off to Buick this morning and waiting to hear back, but could it be that it just was not fixed right the first time? I went to a independent shop to have all the other suspension parts replaced except that strut because it was still under Buick parts warranty and I should not have to shell out more money. Well I thought third time the charm but looks like a fourth!
Oct 15, 2018 at 4:32 AM
  • 55,684 POSTS
Let us know what they say seems strange they can figure it out. Thanks for the video pretty pronounced. It kind of sounds like the "oil can" effect which is metal flexing back and forth. It sure sounds like a strut to me. Please get back to us.
Oct 18, 2018 at 10:14 AM
LISAMC72
  • 14 POSTS
Hi Ken, thanks for replying and I can definitely tell y’all it was the same strut and was replaced for the fourth time in two and half years by the same shop and mechanic.
Oct 18, 2018 at 7:41 PM
  • 55,684 POSTS
They are missing something, did they replace the top plate with the strut as well? I would have a new shop look at it.
Oct 19, 2018 at 4:25 AM
