Suspension noise
50,000 MILES • 1.4L • 2WD • MANUAL
SUDHIR NIMBALKAR
While driving on a robust road there is a noise from front left side. What is the reason and please give me solution to the problem.
Feb 26, 2018 at 5:40 PM
  • 31,937 POSTS
Check for oil leaking from the strut, if it is leaking the strut will be quite wet. Also, check for a broken sway bar link and worn lower arm bushes and lower ball joint. are you familiar with doing these checks?
Feb 26, 2018 at 6:33 PM
