Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Fiesta
Ignition
Coil
Replace/Remove
Suspension coil installation
2002 FORD FIESTA
108,000 MILES
DARREN 1973
MEMBER
1 POST
Replacing suspension coil on drivers side.when I went to put it back on the strut is too low I can’t attach anything back onto it.
Feb 17, 2020 at 9:22 PM
Experienced Mechanic
Good morning,
Are you sure you have the correct spring?
It should be the same height as the old one.
You may want to look at installing a quick strut or one that has the complete assembly with the spring, strut, and mount. It is a plug and play.
https://www.2carpros.com/articles/replace-shock-absorber
Feb 17, 2020 at 9:38 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
