Suspension coil installation
108,000 MILES
DARREN 1973
Replacing suspension coil on drivers side.when I went to put it back on the strut is too low I can’t attach anything back onto it.
Feb 17, 2020 at 9:22 PM
Good morning,
Are you sure you have the correct spring?
It should be the same height as the old one.
You may want to look at installing a quick strut or one that has the complete assembly with the spring, strut, and mount. It is a plug and play.
https://www.2carpros.com/articles/replace-shock-absorber
Feb 17, 2020 at 9:38 PM
