what type of tool would be used to extract or press out these arm bushings?
162,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
GREYGOOSE23
Hello, i would like to know what type of tool would be used to extract or press out
these arm bushings? could you please send a pic of the tool so i could see what i would need for it? - thank you-
Aug 21, 2025 at 6:12 AM
MECHTRIX
  • 599 POSTS
Which arm bushings ?
You can get a so called universal toyota type i think 17 peice suspention bushing removal set online for about 100 bucks that can do most toyotas and certainly the sienna..both front and rear all sizes you might have ...hope this helps good luck.
Aug 21, 2025 at 12:15 PM
MECHTRIX
  • 599 POSTS
Thats the cheapest and best way is to buy it in a set the value is way better becuase if you buy just a single tool it will be expensive and it wont be able to do all the bushings theres a few different sizes so youl need the set do them all
And it can also repair many other models
Best of luck to you .
Aug 21, 2025 at 12:19 PM
  • 55,797 POSTS
I would go over this video to help you see what needs to be done to press control arm bushings out.
https://www.youtube.com/watch?v=g_hj1hRSNgg
Let us know how it goes.
Aug 22, 2025 at 2:28 AM
