Suspension
1995 CHEVROLET 1500
300,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RWALLACE33
  • 25 POSTS
Hey I have recently started lowering my truck from a previous owners 3 inch DIY torsion lift. And I put new shocks in front and turned the keys to lower and inch so far. And it rides a lot better. But the three inch blocks are still in the back. And I feel if I were to remove the rear blocks it would sit far too low to match the front. Even if I were to turn the keys more. Because the front keys don’t look like they have much left to go down. Did this year have stock blocks in the rear? If so would you know what size? 1 inch? Or 2 inch?
It looks as if there’s about 1 inch or so left in the torsion key bolts. Would that be enough to lower the front another two inches? I don’t want to back the bolt all the way out do i? Thanks
Mar 17, 2019 at 5:01 AM
  • 55,433 POSTS
I because they did come with a block in the rear the dealer can tell you the part number if used. As far as the torsion bars go you can move them as much as you want as long as the there is a enough thread on the bolt to be safe. Please let us know if you need anything else to get the problem fixed.
Mar 18, 2019 at 7:31 AM
