What suspension parts should I replace to be safe?
283,000 MILES • 6 CYL • AUTOMATIC
HEATHERPARKS1177
I have a few things wrong with Mr. front end suspension and I wanted to know what is the most important thing to fix so I don’t have a problem driving to work and back. My sway bar bushings need to be replaced and they are out of the mounts and my rack and pinion is leaking power steering fluid I need to replace a boot on my driver's side CV joint axle I need a lower control arm drivers' side and I can't afford it all at once. which part should I fix first in order to be safe?
Nov 27, 2022 at 5:47 AM
  • 55,851 POSTS
You should do everything in the steering and suspension to make the car safe. There is no one part over another that will help avoid an accident. If you need help with a part replacement we can help, please start a new thread for each part that needs replacement. Please post your new question here, you must be logged in.
Cheers, Ken
Nov 28, 2022 at 3:23 AM
