Suspected transmission problem?
148,000 MILES • 4WD • AUTOMATIC
AMISFITLIFE
Recently bought a used car. I have an automatic transmission. I've had two episodes where RPMs rise and I temporarily get little power when pressing on the gas. Research on Google points to possible transmission problems. What things should I look at to narrow down the problem?
Aug 9, 2023 at 7:45 PM
  • 55,732 POSTS
The first thing I would do is run the codes and check the transmission fluid, here are guides that will help:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
and
Transaxle fluid ATF SP-IV or equivalent 7.1L (1.93 U.S gal., 7.71 U.S.qt., 6.42 Imp.qt.)
If the fluid smells burnt, I would change it out. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Aug 10, 2023 at 10:55 AM
