A/C is Warm. High and low side pressures are both 100psi. suspect it is the A/C compressor. I want to change the A/C compressor and need the exact factory service manual steps please. Also, the driver's side electric fan did not come on until it was tapped a little bit with a metal object. probably going to change that as well and need the steps.it is hard to see the clutch on the A/C compressor come on because it appears hidden within the pulley, but since I can't hear it come on, I suspect its not. I also suspect that the compressor is leaking internally causing the 100 psi readings on both manifold gauges and highly doubt it is a bad expansion valve. thoughts?
Aug 7, 2025 at 7:03 PM
