Surging sputtering issue
170,000 MILES • V8 • 4WD • AUTOMATIC
JUSTIN HALL
  • 6 POSTS
I’m having issues figuring out what’s wrong. When I start the truck in the morning it runs and drives just fine but as it starts to reach normal operation temperatures it acts weird. When I come to a stop and then start to go again it almost feels like it’s choking itself out or not firing or bogging. It doesn’t do this every time but occasionally will. When it does do it if you accelerate a little more it come out of it and drives fine. Any suggestions would be appreciated.
Feb 6, 2019 at 3:30 AM
STEVE W.
  • 15,420 POSTS
Hello and welcome to 2CarPros. Being a 1995 you cannot easily scan it for codes, however I would suspect a faulty coolant temperature sensor or the wiring to it being it isn't a constant problem. Your vehicle uses two sensors, one goes to the ECM and the other to the gauge in the dash.
GM # 15326386 is the ECM sensor. It screws into the intake manifold next to the thermostat housing. A trick to changing it out without draining the coolant is to have a cold engine. Start removing the sensor until it is almost fully out. Now squeeze the top radiator hose hard. Release it and as soon as you do remove the sensor and screw the new one in, if needed a helper on the hose can make it much easier. Squeezing then releasing the hose will create a small vacuum inside the engine for a couple seconds, that is usually enough time to swap the sensor and only get a tiny amount of coolant out of the system.
You can test the sensor first if you have a multi-meter. Simply check it's resistance using the table I posted. However, you would need it to be acting up while this happens to be sure it's the part that's failing.
Another option would be to find a shop with an older scan tool that can read the data from the PCM and see what it shows while it is acting up. However that could take a while unless it always acts up.
I would also look at the connector real close, corrosion or damage can cause a lot of problems, many times more than failed parts.
Feb 6, 2019 at 10:20 AM
JUSTIN HALL
  • 6 POSTS
Hello so I have recently done a tune up on the motor and i noticed that temp sensor was broken so I replaced it once already is it possible I just have a faulty sensor? Also I know there is another temp sensor on the driver side of the block that I have not replaced. Would that one effect anything? Also I have started it on a cold morning and noticed an exhaust leak on the back side of the manifold and I realized the rear bolt was broken off could this effect anything? The leak isn’t major and most times I can’t even hear the noise. I do have a video of it running when it acts up if you’d like me to attach it?
Feb 7, 2019 at 3:05 AM
STEVE W.
  • 15,420 POSTS
I would check the wiring to the sensor. Being it was broke off the internal pins may not be making good contact and causing faulty readings.
The other sensor is for the dash gauge, if it is reading OK, the sensor is OK.
The exhaust leak can cause the O2 sensor on that bank to read a lean condition and add more fuel. as well.
We always like videos.
Feb 7, 2019 at 9:21 AM
JUSTIN HALL
  • 6 POSTS
Alright, I’ll check it out. And my only o2 sensor is a three wire one on the right bank there isn't even wiring for one in the left bank (it is dual straight pipes with mufflers).
Feb 8, 2019 at 3:52 AM
JUSTIN HALL
  • 6 POSTS
Here is the video of it doing it. I am pressing slightly on the gas.
Feb 8, 2019 at 3:57 AM
STEVE W.
  • 15,420 POSTS
What other modifications are on the truck? It would have only had one O2 sensor. plus a MAP, throttle position and coolant temperature. Does it idle okay?
Feb 8, 2019 at 12:04 PM
JUSTIN HALL
  • 6 POSTS
Nope just the dual straight pipes. Yes it idles perfectly, good oil pressure, runs good when driving. It’s just does it when I go from a stop to take off.
Feb 9, 2019 at 1:56 AM
  • 55,770 POSTS
It looks like the TPS sensor is not working right but to be sure lets run the codes. this guide will help us:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Feb 11, 2019 at 3:10 AM
STEVE W.
  • 15,420 POSTS
Did this all start after the tune up? Or was this the reason for the tune up and it didn't change? What did you do for a tune up?
Feb 11, 2019 at 6:08 AM
JUSTIN HALL
  • 6 POSTS
It started after the tune up. I just did a standard tune up. Checked cap and rotor cleaned them up even though they were good. Plugs, oil and filter, I did flush the coolant system also, replaced that coolant temperature sensor and that’s about all I can think of. I did try cleaning the contacts of the plug on the temperature sensor and it didn’t seam to help. I can try replacing the TPS sensor and see what that does. Also, I pulled codes and all I got was o2 sensor.
Feb 12, 2019 at 5:45 AM
  • 55,770 POSTS
I was going to say coolant sensor but you did that. did you manage to run the codes?
Feb 13, 2019 at 2:51 AM
STEVE W.
  • 15,420 POSTS
An O2 sensor could cause problems, but usually that would occur all the time not just at a part throttle situation, however it would depend on what it was actually doing. As the issue started after the tune up, I would just go over what you did, just to be sure that a connector pin didn't get bent or another item like a vacuum line or wire didn't get knocked loose while you were working. BTDT before.
Feb 13, 2019 at 5:09 AM
