Surging only when accelerating after warms up
156,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
CORY BARNETT
Okay, I am not a dummy so from the start I have replaced all sensors, wires and hoses related to the fuel/air systems. The only thing I have not done is replace the fuel pressure regulator. My truck surges only when in drive and only after it warms up. The first five minutes she runs great. I took the TBI off and cleaned the injectors and noticed the spring in the fuel pressure regulator is stuck. Could this cause the surge? I figured if it was the for it would also surge in park. I am stuck any suggestions or actual answers. The truck is my only means of transportation I need her back on the road.
Jan 6, 2017 at 6:49 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and IAC hole with choke cleaner if you have not already. then check fuel pressure with a gauge auto parts rent it, see link.
Jan 6, 2017 at 10:59 PM
STEVE W.
  • 15,409 POSTS
The sticking regulator could cause it and it likely would act worse under load.
Jan 7, 2017 at 2:22 AM
