Surging when applying the brakes
49,000 MILES • 2.1L • 4 CYL • 4WD • AUTOMATIC
PHOTOJOE
Car surges forward while applying the brakes.
Jun 30, 2018 at 12:17 AM
  • 110,248 POSTS
HI and thanks for using 2CarPros.com.
Based on your description, I am not 100% sure I understand. Do you mean the engine surges or the car feels like it does?
If the car feels that way, chances are it is a brake problem. Basically, rotors or drums can warp over time giving the feeling of a surge In most cases, you will feel the steering wheel shake if it is the front. The rear is a different story. What I do is when moving, apply the hand brake keeping my hand on the parking brake release the entire time to determine if it is a rear brake issue. Caution: If you try this technique, you must have the park brake release pressed the entire time and gently ease into the park brake. Do not jam on the park brake because it can cause you to lose control of the vehicle.
If you determine that the brakes are not the issue, I would next recommend checking for an engine vacuum leak, especially if the engine RPM surge when applying the brakes. The power brake booster is powered by engine vacuum. Since this only happens when applying the brakes, there could be a leak. Here is a link that describes how to check for an engine vacuum leak:
Check these two things and let me know what you find.
Jul 1, 2018 at 12:08 PM
PHOTOJOE
Sorry about being vague with the information. This situation with the car has only happened four times in the past year and half but is a cause for concern. The car accelerates momentarily without stepping on the gas pedal. On one occasion I was slowing down while approaching a red light at approximately fifteen to twenty mph. I was about to apply the brakes when the car suddenly surged. I thought someone bumped me but there was no vehicle behind me. I had a couple of other close calls once pulling into my garage and another time pulling into a parking space. I realize with this situation only happening a few times makes it difficult to diagnose but any help is appreciated.
Thanks,
Jul 13, 2018 at 9:55 AM
