The car surges under normal driving conditions but if I turn off ignition while driving then back on the engine light goes away and the car then runs normal with no surging but only for a little while. I have replaced coil pack, injectors, fuel pump and filter. I have checked and there are no blockages in the fuel line also replaced crank sensor and timing sensor. It feels like the fuel delivery cannot keep up it is obviously something electrical as when I restart its fine. So any advice would be great. Can the accelerator pedal position sensor be of any issue?
Mar 16, 2018 at 5:02 PM
